GuitarFreak simulation d'electronique
thomick
Message par thomick »
hello
l'outil de recherche du forum ne donnant aucune réponse je poste le lien ici: http://guitarnuts2.proboards.com/thread ... calculator
GuitarFreak is a spreadsheet that plots the frequency response of an electric guitar, with all the main variables adjustable, so you can see what happens when you change pickups, or try a different pot value, or a new capacitor, and also what happens when you turn the knobs. The advantage it has over circuit modelling programs such as LTSpice or 5Spice is that the graphics respond immediately as you press buttons and move sliders etc, so it's very interactive. Also, it can include the main non electrical effects such as pickup placement and string harmonics.
The model is intended to be visual and highly configurable, and many changes to component values, tone control circuits and pickups etc may be modelled and quickly compared.
The purpose of Guitarfreak is to help with design choices about wiring and pickup selection. It is intended to be complementary to listening and testing, by giving extra insight into how tone is affected when changes are made or when control knobs are adjusted. It can help answer questions such as:
'what happens if I change a pot value?'
'what treble bleed values would best preserve my tone?'
'what will a TBX tone control do on my guitar'
'what component values will preserve the treble best if I try series wiring?'
'how important is the guitar cord?'
'How similar is pickup A likely to sound to pickup B?', and
'How can I make pickup A sound more like pickup B?'
The effects represented include pickup type, pickup position, tuning of strings, scale length, fretting position, picking position and the electrical characteristics of the pickups and guitar circuitry as far as the amp input. Up to three pickups can be combined in series, parallel and in or out of phase. Tone controls can be before or after the volume pot, and several configurations of tone control can be selected. Different guitar cords can be tested and treble bleed circuits of various types tested. Several plots can be stored so that the results can be compared.
Re: GuitarFreak simulation d'electronique
Je vais y jeter un coup d’œil, ça a l'air intéressant !
Merci !
Alors ? Tu peux expliquer ? J'ai jeté un œil mais rien compris à ce qu'il fallait faire et comment...
(en même temps j'ai jamais rien bitté à Excel)
Mais du coup, le résultat n'est que visuel ? Ca va pas m'avancer des masses, ça...
thomick
il y a un exemple d'utilisation ici: http://www.strat-talk.com/threads/guita ... st-2486027
Oui c est visuel. Le principe est la modification des fréquences de sortie en fonction de l’électronique.
